Knocking after injector change
Three hours can be sufficient time for it to cool off.
In my old man's old truck, when the pump was going out, we'd go to the store, be in there for 15-20 minutes, and it wouldn't restart. Cold water trick fired it up.
Rupert8
Guerneville, CA
Air intrusion. Right. We'll, I replaced all the fuel return lines recently. Where else are common points of ingress? I'll look into that.
Fuel return leakage. Some people even put a check valve in the main return at the back of the drivers side head too.
Otherwise common paces are the sealing olives on the hard lines, loose filter, fuel heater connector leaking...
94f350
Princeton MA
I had a similar issue on my truck, started out with a really bad leak out the injectors because I replaced the o rings incorrectly, said "**** it" for a few days and one day I started it up after running it for a few hours and it knocked like a ************ until I shut it off, then ran fine, I fixed the fuel leak, then the truck ran great. I think you might just have a bad injector. I'd throw the old ones back in and see what happens. Your IP could also just be wore out because the new injectors are gonna take more pressure to pop than old ones. Might be a good idea to pull the fuel filter off and fill it with atf and see what it does, maybe throw some in the tank too. Hope this helps.
Rupert8
Guerneville, CA
Sorry for the slow reply. I'm about to change out the olives (I set up another thread to ask about how to approach that). I'll report back. Thanks.
Alleycat
