So this is for the "Nay sayers" and the uninitiated curious folks like me. But I pulled apart the IP that "went bad" on my dually several months ago after haven drank WMO for 6 or 7 months. This was probably the original IP off the TIDI, so it wasn't WMO that killed it, it was age and WMO may have helped at the end. Eventually l plan on "rebuilding" it, but for now I wanted to look at it and hear about the "wear areas" and such. I want to know how am I destroying this piece of super hardened steel?
I did notice that the screen that is right where the fuel comes in was covered in a fiber type material, it has to be from filter media. I tried to take a picture. The other things I noticed are the inside of the ring where the rollers roll is a little shiny and the inside of the housing itself has a rubb area, and the seal that the filter goes around is kinda crispy cooked.
So, what am I looking for as far as wear the can be attributed to thicker fuel?
My threat!; Y'all better not hijack this thread, this is a serious subject, we're NOT going to digress into electric fuel pumps, and Gear Vendor ODs! I'll tell on you if you do, so be good!
