IDI Parts
BlindAmbition
SoCal
As my project is wrapping up, I have a pile of parts for sale, offer what you think is fair for both of us. I can ship to the 48 states, I'll come up with prices if required and add pictures as I figure out how to add them all.
V-belt Saginaw power steering pump bracket
Brass/copper radiator from a bullnose, pressure tested with a bike inner tube and held pressure fine
Factory turbo pedestal
Factory turbo manifold collector piece - y pipe that connects both manifolds
Factory turbo uppipe slip fit piece
Factory turbo in pieces, needs a CHRA
7.3L van exhaust manifold
Passenger exhaust manifold
Bullnose tachometer instrument cluster + sensor + wire pigtail in good shape
Bullnose manual pedal assembly
Bullnose door panels with power window and lock slots
Bullnose passenger seat mount
ZF5 cab floor piece
Injection line sets
3 Injection pumps,unknown condition, likely all cores, will get part numbers today
30+ injectors
6.9 fuel filter bracket
Vacuum pump and bracket for V-belt motors
Laycock P-type overdrive (GearVendor without the name) with C6 adapter and coupler
ZF5 S5-47 with a Ford rebuild tag for a small block ford pattern, not for IDI but posting anyway
Austin86250
idaho
Bullnose tachometer instrument cluster and sensor
Bullnose passenger seat bracket
Injection line sets
30+ injectors
what condition is the bullnose tach setup? and what are you asking?
BlindAmbition
SoCal
Added more pictures, responded to all inquiries. Not sure how to do pricing, only have ebay for reference
Cubey
Van dweller
USA
PM sent for the Saginaw bracket.
Hopefully you're getting the annoying spacer/bushing with it that goes behind the bracket for mounting it. Changing Saginaw pump on vans means taking out the bracket due to being unable to remove the pulley in vehicle, and it was a bit annoying putting the bushing back. That's how I know about that darn thing, having messed with it a bunch. It's required or the bracket will be loose.
So keep that in mind if it doesn't come with it, you may need to find or make something close.
Golden Helmet
Monterey County, California
Thank you for the tip! That is very good to know, I don't know for sure if I'm going to do the conversion, but I want to document this swap as much as possible for anyone who wants to do the swap but can't find an IDI van in the junkyards. If nothing else, it's another rare part for my collection. I would love to ditch the supercharger in my truck for a Saginaw pump, but I have no idea how that's going to work since I'm set up with hydroboost.
BlindAmbition
SoCal
I did Saginaw with that bracket and a hydroboost setup, pretty sure there are pictures of what I did in my build thread. I can take pictures if you need. Learning what all the different types of fittings were to get the correct pieces was the hardest, followed by making hoses. Not too bad overall I thought.
Cubey
Van dweller
USA
Van hoses might be all you need, if they can reach the gearbox on a truck. Trucks & vans all used the same gearbox so that end of the hoses should be right. And the return line end at the Saginaw pump is a bare 3/8" hose that slides onto a hose barb.
Oh and beware when buying a Saginaw pump. O'Reilly sold me an incorrectly rebuilt pump. The company put this in backwards. The bushing should be facing into the pump with the pump up against the bracket. The stud is what fits into the slot of the bracket.
Left is correct, right is wrong. O'Reilly gave me a refund since I ended up ordering a bare pump and reused the old reservoir, and didn't need it anymore. Either return it or turn the nut around. I didn't want to void the warranty on a slightly expensive retail priced pump by doing that. Just don't be tempted to grind the bracket if you run into this because it's not a bracket issue.
BlindAmbition
SoCal
Updated list, cannot seem to edit my original post any longer. All messages responded to, this is what remains.
Brass/copper radiator from a bullnose, pressure tested with a bike inner tube and held pressure fine - $100 + shipping, local pickup preferred
7.3L van exhaust manifold - $30 + shipping
Passenger exhaust manifold - $30 + shipping
Bullnose tachometer instrument cluster + sensor + wire pigtail in good shape - $250 + shipping, last one I saw sold on eBay for $350+tax+shipping
Bullnose manual pedal assembly - $150 + shipping
Bullnose passenger seat mount - $50 + shipping
Cab floor panel for ZF5 manual swap - $100 + shipping
Injection line sets - Let me know what you need
D code injectors - $100 per set of 8, untested, assume cores,
6.9 fuel filter bracket - $50 + shipping
Vacuum pump and bracket for V-belt motors - $50 + shipping
Laycock P-type overdrive (GearVendor without the name) with C6 adapter and shaft coupler - $600, ideally pickup
