hacked89
If you are going from a flatbed to a standard bed or vice versa you may be in a position to replace the rear harness. Below is the 5 wires you need to cut and splice to a replacement harness. Typically Mr Tailight or similar. Bronco graveyard uses Mr. Tail light. The bulb sockets are the pre-brick nose. 1156 and 1157 bulbs. The OEM mapping I have below is for C6 Bricknose but there’s a lot of crossover between years.
5 wires to cut and where to cut it:
Mapping
