How to Connect Primary Grounds on an IDI
Status
Not open for further replies.
hacked89
Bucks County PA
Grounding is the most overlooked, critical component of your electrical systems function. In your vehicles electric system the power flows towards the negative terminals. Your truck doesn’t care how the grounds are bolted but it’s going to find the least resistant path to flow. That includes if you don’t have a good primary ground design, and your high amp components flow through your secondary grounding straps while you smell a funny burning and the gauges occasionally dance, it will do it.
I’ve done various configuration testing on my run stand, and if you have a question about a scenario, ask. This is the best setup I’ve found for the primary grounds. There are many combinations to do this and aslong as you follow the basic principles your fine. This is just to visually help someone that may be lost with an example. There are also a number of secondary grounds via small straps and black wires in the harness as well as black with white stripe that won’t be covered here.
Let’s get started.
The most thirsty component for a good ground on your truck is the starter solenoid bolted to your bell housing followed by the starter relay on the passenger fender. These two locations should be a high focus of your attention if you deviate from the stock wiring diagram, which I do in this example.
Many threads of why does my starting system click, work poorly, not work are tied to this area of the truck. Your starter relay even gets its ground through the fender. Any ground should be free from paint, and I used a thin layer of dialectic.
High level summary of your basic requirements:
1. ground from each negative terminal on the batteries to front of block
2. engine to chassis
3. engine to body
4. body to chassis
Example:
You can see the battery to front of block and locations, the chassis tie in and the body tie in
The body tie in leads to the passenger side fender:
The body gets a dedicated ground from the drivers side. I’m not a fan of grounding off the heads or back of the block.
Dedicated ground for starter:
Dedicated ground for alternate:
Let me know if you have any questions.
hacked89
Bucks County PA
You may ask why did I cover only primary grounds in detail. Incase you need it for a reference and to add to this “grounds” thread, below is a full list of locations for primary and secondary.
Ground G111: RH Frame Near Battery
Ground G116: Near Electronic Engine Control
Ground G117: Near Ignition Coil
Ground G119: Behind I/P Near Center
Ground G155: LH Rear Of Engine
Ground G156: Center Of Dash Panel
Ground G203: On RH Side Of Engine
Ground G208: Near Throttle Position Solenoid
Ground G209: Center Of Dash Panel
Ground G210: At Electronic Voltage Regulator
Ground G211: Near Starter Motor Relay
Ground G301: Near Underhood Lamp
Ground G502: Behind LH Side Of I/P
Ground G701: Behind I/P At Center
Ground G703: At Brace Under Steering Column
Ground G710: LH Side Of Dash Panel
Ground G711: LH Rear Of Engine
Ground G751: At LH Side Of Engine
Ground G752: In LH Door
Ground GS01: LH Inner Fender Behind Headlamp
Ground G802: At RH Inner Fender Behind Headlamp
Ground G803: At Fuel Sediment Bowl
Ground G804: At Lower Hole Of LH Quarter Panel
Ground G805: At RH Inner Fender Behind Headlamp
Ground G903: At LH Side Of Crossmember
Ground G909: At Lower LH Cowl Access Hole
Ground G1006: Rear LH Side Of Frame At Rear Crossmember
Ground G1201: At Front LH Side Of Engine
Status
