How to Adjust Injection Pump Side Lines Without Removing Other Lines
hacked89
Bucks County PA
This is simple but time saving.
Let’s say you have a leak or need to remove a single line from the injection pump and you don’t want to have to undo everything or other lines.
Take a 3/8 ratchet and 2.5-3” extension. Then a 5/8 crow foot and grind the sides down parallel. Remove the feed line only, and you will be able to access all other lines.
XOLATEM
Virginia... in the brambles
Another nifty idea from the crafty guy in PA...
If I lived near there I would be hanging around outside your shop hoping you would let me in and teach me a few things...you might even get me to clean up any spills and take out the trash....and I don't take out the trash for just anyone...just to absorb some of that craftiness...
Gotta hand it to you...you got talent...
That intake setup is right cool...and you have some nice injector lines...
Where can I find one of those line clamps...my lines are missing that one...
hacked89
Bucks County PA
Thanks guys. Those are part of injection lines that I get. There are plenty of resellers of various levels of quality of those clamps. I’ve been loosely throwing around buying the ones I get in bulk and reselling them. They are not from China. Unpopular opinion but not that I think China is bad quality, it’s just that it’s usually bad quality because of American greed. Many companies rather compromise quality to increase profit margins. China will build to whatever level of quality you request.
hacked89
Bucks County PA
So I assume if you need to loosen the lines to adjust timing, it’s a good practice to also loosen the line clamps that are close....?
Thanks Hacked!!
If you go more than a dime / dime and a half of timing it’s a good idea to loosen the injector lines from the injectors starting with the side your turning towards but usually need to undo both sides.
