How good of a motor is it?
bdemutis
Pa
Ok thanks I just hope if it's the oil pan that it's not like the 7.3 motor I don't want to pull another engine
tanman_2006
Seiling Oklahoma
You will have to pull the engine to re rtv the pan. Its less work that pulling the axle. Typically its not an issue just some minor seeping
bdemutis
Pa
Ok well I seen they make a oil pan gasket for that pan I wonder if it's possible to drop the pan in the truck put the gasket on and bolt it back. But my oil leak seems to be coming from my dipstick housing on the side of the pan.
bdemutis
Pa
It actually started to leak I think when I put the new crank case breather on but I just hooked it into the intake as normal.
tanman_2006
Seiling Oklahoma
What do you mean by into the intake? The CDR can be a ******, that's why I suggest a road draft tube if your engine is doing fine w/o cdr
tanman_2006
Seiling Oklahoma
If the leak just started then it sounds like you aren't exhausting the crankcase pressure well enough.
Post pics of how the CDR is routed
bdemutis
Pa
Ok will do when I get home I mean the truck runs great no blow by or anything when at temperature I don't see any blue smoke coming from my exhaust I only have black smoke come out of the stack when I'm in neutral and mash the gas and rev it I get a little puff.
tanman_2006
Seiling Oklahoma
Sounds healthy but if the CDR isn't right and you get too much crank pressure the you need to start to worry about seals and blow by increasing.
bdemutis
Pa
Well I think it might have to much oil too I'm on a hill and I'm showing maybe a quart to hight it smells like oil no diesel or anything else.
bdemutis
Pa
Oil level is high
bdemutis
Pa
This is my ghetto cdr repair and my oil filler gas
BrannonB
