7.3_IDI_guy
Currently ******'
I've been looking for an electric fuel pump and I was wonderin how good a Holley Black pump is. They are supposed to be amazing and dump fuel but never tried one
I figured it would dump fuel in and make the truck roll some coal
Lets not use you to set the bar on this one, ok kiddo?Im using a holley blue unregulated
Lift-pump pressure has very little to do with fuel delivery at the injectors.
About all increased lift-pump pressure at the injector-pump will accomplish is to blow a shaft-seal and flood the crank-case with diesel, hence my recommendation of a regulator.
7.3idiguy,
wanna really roll some coal?
first go in the kitchen and get one of those big plastic trash bags.
Put it over your air filter. Make sure it's tight fitting, use duct tape if you need to, we don't want any of that pesky oxygen in there.
You'll be rolling smoke like mad man!!! as a side benefit you'll save alotta money on air filters.
best of luck,
Drew
Where would I go about getting one of these regulators you speak of? I have no idea what it does really. I just know that fuel pump will put out lol
Holley makes a adjustable inline fuel pressure regulator that would be a good idea if you are going to use a pump with more than 7 psi (like the Holley Black). $27 at Summit.
Heath
kinda being a ******** there ain't ya?Kinda bein a smart ass there ain't ya
That appeared to have been answered. On a side note, it is a 'regulator' as such it regulates something yes? in this case fuel pressure.
Educate yourself just a little on how the fuel system of a diesel works before you start destroying it please.
