FREE STUFF 1977 F250 parts
SHIP4BRAINS
Central Iowa
I have some parts left over from my 1977 F250
Axle shafts from the Dana 60 rear axle.
Complete rear drum brake setup ( both sides ) for the same axle...newer drums, pads and all other components. Brakes were recently redone, along with new bearings and seals. The bearings have been exposed to dust since being removed....clean or replace these.
One note: This f250 was a crew cab camper special. This truck had wider rear brakes than the standard f250.....1/2" wider that standard. These will NOT fit on a standard Dana 60 housing ( I found out the hard way trying to swap ) ....the entire axle housing on the camper special axle was 1" shorter overall, allowing 1/2" wider brakes on each side.
I have the axle housing too. The diff is shot.
IF you want em, lemme know
jdchristian3
shenandoah valley of VA
how much will do you want (shipping included- i live in 22630 zip code) for the Dana 60 rear end??? need parts. drum to drum basically is easiest...
Stubburnjd1
