Finding the limits of my centrifuge and the sweet spot
Mt_Man
Portland, Oregon
So I got a question the for those that continuous flow centrifuger out there. I just set my single pass centrifuge up so I could use it as continuous with a pump. First pass is from my dirty tote to a clean tote. Second pass is the recirculated from the bottoms of the clean tote through my fuge and into the top. I am hoping it gives it a mixing attribute. Also thought I could flow a little more. Just using my collection neumatic double diaphragm pump. Found out that the centrifuge plumping on the clean side can only handle about 112gph. Which is nothing for the diaphragm pump so it's turned way down, but could have been bad if I wasn't watching. I noticed at low air pressure it doesn't stay very consistent with it's flow rate and will speed up sometimes. It almost overflowed threw the bowl drain tube. I figured it was coming and was ready. The fuge has .5 inch drain coming out clean and bowl drain.
So my question is what would be a good gph for it when it's set up this way? Is it better to do the 3gph I do from the dirty tote and gravity? Or should it be faster like 40-80gph? Trying to size the pump I need. I have several to choose from. I know I will have to pump about 3-5times the tote capacity to probably get it clean clean. The plan being, go until nothing really comes out in the centrifuge. Just like a lot of you do.
I am also trying to see how well my single pass is doing.
Mt_Man
Portland, Oregon
So been testing out the recirculating method. Seems to still be pulling out sludge. I rigged up a smaller pump that is doing about 75gph. I can't get it to run slower haha. Did about 3 hrs yesterday and doing another few today. Seems to be running happily. It is flowing fast enough to cause a dribble out of the bowl drain which is not a big deal.
Mt_Man
Portland, Oregon
Ran the recirculating setup for 8hrs yesterday. And this is all it pulled out. So I think it is decreasing. I will fuge it into my other clean tote and see how much it gets out.
I wonder how well the tote is mixing? I kinda want to try it with a 55 gal and see if mixing it up would be better. Kinda see why the pressure fuges they use a barrel instead of totes easier to be confident that it's getting clean.
Mt_Man
Portland, Oregon
Oh that was the third time running the set up. Previous runs pulled out more. Each time seemed to decrease the amount being pulled out.
Think that is a good sign
Mt_Man
Portland, Oregon
Pump/fuge one last time as I transferred to my second clean tote. Got even less in the fuge, about 2.7hrs to transfer about 250ish gallons. Puts me in the realm of 90gph. Little higher then I was figuring. Still looks pretty good. I am finding that I need a more controllable pump. Probably try an electric pump next batch.
Doing the first pass of the next batch right now.
Kevin 007
Full-floater
Nelson BC Canada
Well I also think that since you are pulling less sludge out on every pass, it is working effectively.
Have you given any thought to a pneumatic oil transfer pump? They will meter down to a pretty slow flow and they last. Of course it would have to have a steady supply of air and running a compressor may not necessarily be efficient
Mt_Man
Portland, Oregon
I didn't think of that. I was running a compressor to do the testing with my pneumatic diaphragm pump so it would be similar. That is a good idea. I don't have one, but I will keep an eye out for one. I was thinking of adding a bypass valve and having some volume dump back into the clean tote. Very similar to the continuous flow centrifuges. I think a dc motor and speed control or a vfd would be nice.
Fattima
Australia
Like your work. I'm thinking of doing something similar but was looking at using a pump feeding a header tank with a float switch to cycle the pump to keep the header tank topped up with oil. I've got a 12V gear pump here and a float switch is pretty cheap. Will have an overflow back to the main tank should the switch fail.
Mt_Man
Portland, Oregon
Yah that would be a good idea. I built this a few years ago to do small batches. A buddy asked for me to fuge some oil so they could put it back in a dump truck that leaked really bad. It was worn out and only used it around the farm. It would be easy to add a overflow return. I think the best way to do it would be to have another tote and pump all at once and then let gravity do it all.
Mt_Man
Portland, Oregon
So hopefully you guys judge me fairly lol
I cobbled this together with stuff I had squirreled away.
cookoo:popcorn
Little 12v fuel pump facet posi-flo efp-3. A friend suggested getting a old laptop/monitor power supply. We have a great little surplus electronic store (surplus gizmo) that all sorts of neat stuff. But grab one up and a cord for $12. Looks like the pump only draws about 0.5amp 120v before the power supply converts it. So I got lots to work with from this 5amp power supply. For upgrades. Testing faze. Looks like the pump is doing through the fuge is doing about 4 cups a minute, so about 15gph. Which is slower then I was hoping but not to bad. Bigger pump will be happening someday. But I don't have to worry about overflowing the fuge anymore lol:rock:
Mt_Man
Portland, Oregon
Well after letting it run for about 24 hrs I cleaned it and found that the bowl had almost filled completely with sludge. It slumped when I shut it down to clean so it did not make for a good picture. I am thinking that a little slower might not be a bad thing? At 15gph it should take 18-19hrs to do a 275 gallon tote. That would mean it did a little more then a tote worth of recirculating. I will try it with an 12volt lift pump from a 24valve Cummins, should be around 50gph. We will see if it changes the amount pulled out for the next batch.
Mt_Man
Portland, Oregon
Well I have been running the fuge pretty constant since the 28th post. Cleaning two times a day. morning and evening. I am getting less and less. I think if tomorrow morning comes back with less it will be time to call it good. This batch would have gotten about 5 or 6 days(~120hrs) of recirculating filtering. I don't quite remember exactly how long it has been running. I will keep better notes next batch. Gotten way more out then I though I would which is neat.
Mt_Man
Portland, Oregon
We'll do the final fuging. Looks like the pump is doing more like 25ish gph. Pretty impressive little pump. Definitely quieter, cheaper, and simpler then my diaphragm pumps. Also got some nice barbed fitting for a few bucks and make it nice clean looking.
Mt_Man
Portland, Oregon
Well got another two batches done.
One batch first pass gravity took about 48hrs. Cleaning twice a day.
Recirculate fuging 85hrs(3.6days). Cleaning twice a day.
Last pass and into the final clean tote. I think that was about 20 ish hours. Did it over two days. Didn't get much sludge out.
other batch must have been really clean.
first pass gravity 36hrs. cleaned twice day. but didn't really get anything.
recirculated fuging for 48hrs not getting much out. Cleaning twice a day.
Have not done the final pass yet.
Working on cleaning some water marine diesel for a friend.
