Remove the bolt that holds the door handle on (the part you lift to open the door, 10mm I think). Remove the screw behind it, the screw up in the corner by the mirror, and a couple screws at the bottom. Lift up und out. No more push-in fasteners. Be aware of the door lock plunger when you put the panel back on.
