matt-jenkins
Any of you running a cummins with an E4od? I have been reading and it seems like you need both an adapter plate and a stand alone transmission computer to make the tranny properly work with the cummins.
Now from my very amateur understanding the new computer is nessasary because the cummins and IDI have different torque curves, rpm ranges etc. Would putting the 3200rpm spring in the Ve pumped 12 valve make the rpm range/torque curve close enough to that of the IDI to make a $800 tranny computer not necessary?
