Common oil leaks on the 6.0
Oledirtypearl86
Whitehall MT
So I haven't had a chance to dig in yet but what are the most common places a 6.0 leaks tat causes it to run down the back of the motor it's not a big leak just enough to notice if I park it for a few an let it idle
DaveBen
Ukiah, Ca
The turbo oil lines. Especially the drain line going to down to the manifold pan. They can run down the back of the motor.
Depending on the year, could be your icp sensor too.
I know the glowplug harnesses will leak like a sieve as well.
Oledirtypearl86
Whitehall MT
Yeah it's a 03 it's my excursion and it's really not a bad leak maby 2 quarter sized drops after idle ing for 30 min
3Kp
Indiana
Mine was leaking from the O-ring under the filter housing. I replaced the O-ring and the leaked stopped.
I took brake cleaner and air gun to clean the valley out the best I could to help me trace the leak.
