The clutch line kit from Russ repair is worth the money in my mind. It really does make it pretty simple. Hook everything up in the truck, fill the master with fluid, open the bleeder on the slave, and close it once the fluid starts to come out, pump the pedal a few times and you're done. The 90 deg fitting goes to the Master cylinder (there weren't any instructions or drawings).
