clutch fan problem
avs0730
long island ny
ok boys i have alittle problem with my clutch fan. I change the clutch fan because it went bad (no wires cut). So now its getting hot i needed an a/c compressor so i had my buddy put in the compressor and he tells me that the pressure is getting too high and wanted to know if i change the clutch fan. I told him yes of course. So after 3 days of figure out the problem i kept using the truck and kept transporting. I notice that the temp goes pass 210 and then it goes down after i get off the gas. it has new radiator, a/c condensor,dryer,evaporator/heater core, orches (mispell), and new lines from dryer to compressor both lines. i notice im not getting signal on the park lockout its the green wire i believe its one 1. any info how to fix this. also have a p0480 and p0243 code
JU57US
