circular base flange at end of exhaust?
rreegg
Puget Sound
That's fairly accurate.
You know who pollutes the most? Shipping boats and airplanes, by 30x as much as OTR trucks. But are we doing anything about those? Nope.
Great point and appreciate hearing this. When it comes to emissions and stuff though my brain just cannot compute all the considerations - to be fair I believe the Passenger Miles per Gallon (or emissions equivalent) of airplanes is often quite efficient compared to single passenger OTR transit.
OTR transit BUS is more emissions friendly than an airplane. As for a tractor trailer, I think I remember reading once that it's still better, especially the later year systems with DEF, but I can't quite remember.
But then we got all these rich dumb butts with private jets, in my opinion those should be banned.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Problem with any emissions equipment on planes is… you can’t. Can’t add anything that compromises reliability, and that stuff is highly regulated by the FAA
And that's why there is talks about EV planes and hydrogen planes. I'm eager to see what the future holds, hydrogen sounds pretty neat.
1mouse3
il
I dont see this ev stuff to be viable, if lithium are going to be the focas of development. There too volatile for something that has no benifits, to out weigh its state and is a rare earth item of scarcity. With a ice engines, there is other subsitutes for fuel. For gas there is wood gas and diesel can run off the waist oil, thats common use in machinery. I think this ev push using lithium, is a mean to cripple are means of movement.
If were to go ev, there needs to be proper devlopment of a viable power storage that has a fast charge comparable to the refil of a ice engine. Flow cells are a path I see to get there and this one, is about about all I see in the persute of that path.
The tech has been around and has show good stability.
There has been develpment for it in home use but dose not seem it has got a lot of traction.
One of the ev guys at work is working with engineers about using sodium batteries, so it's already in the works. Lithium batteries are definitely too dangerous in my opinion for planes. Yet we all keep them in our pocket.
I'm in support of an EMP and going horse and buggy. Oats and hay are sustainable and can make my garden grow after my horses intestines have processed them.
Now THATS a "circular flange exhaust" that stays cool.
Next thing you know we're going to put a centrifugal starter on our idi's and put a mechanical linkage kill switch on them. Who needs batteries anyways?
Rdnck84_03
Kansas
I already have a gravity starter on mine, all I need is the mechanical fuel shut off.
James
1mouse3
il
Id strap a small briggs to mine, rebuild the magnito and start a methanol still.
Really you just need a good hill on your place to park at the top of when you get home. From cold, I think these trucks start better with a rolling start than with glow plugs or ether.
1mouse3
il
The term Im looking for is pony motor but not finding the video that inspired the thought.
Hey, I prefer Briggs over Kohler myself too.
If the briggs has a carb, Im for and if not its the kohler Id take since stuck to carbs longer.
I'm familiar with a pony motor. The '59 D6 I had was converted elec starter from a pony motor. I'd stick with a hill though. A a pair of draft horses to pull it back to the top if you don't get it the first time.
Rdnck84_03
Kansas
I think the gravity starter is a viable option. We will be driving around while their still trying to set up the still and pony motor. ;Poke
James
