Cheaper Alternative to NAPA Coolant Test Strips
bilbo
North Dakota
I have a bottle of NAPA coolant test strips that I bought a couple years back when I got my IDI. Last time I went to test coolant the strips had gone bad. The bottle contained ~50 strips and I had used maybe ten. A new bottle of strips from NAPA is $40 and I was wondering if there was a less expensive alternative, or even just a smaller package that would work. I wouldn't have a problem paying $40 if I used them, but with only the one diesel engine I'll never come close to using them up before they expire. Does anyone know of any other sources or brands?
Fleetguard sells individual strips. Part number is CC2602B.
Cubey
Van dweller
USA
I run Zerex G-05. No additive needed. Presumably no testing needed. Pretty easy to get at auto parts stores.
bilbo
North Dakota
Thanks, I'll look those up.
I have a bunch of that in my garage. It's what I use in my newer Dodge pickup. Does the SCA ever need to be "topped up" with the Z05? I guess I'm not sure it needs to be topped up with the NapaKool, it's just been quite a while since I've tested it. I haven't had to add coolant or anything though.
Cubey
Van dweller
USA
I don't think so. I have a small leak and just keep lots of extra in the RV for topping off. One less expense, no strips. It's been in there 4 years so far and 16k+ miles, crossing mountains out west while towing and has been fine. But it's also a 6.9 so it has thicker walls.
