Can you run wmo in alh tdi jetta...
Mightyfordranger
Ohio
Curious how picky these engines are. Can you feed it wmo mix with gasoline and some diesel added in? And filter the ***** out of it before you pour it in? Or would it roach the IP?
Oledirtypearl86
Whitehall MT
@Mightyfordranger you should be go as long as the oil dosent get to thick the up is a Bosch rotary set up and are pretty good and reliable the worst thing for them is spinning dry but in my 01 I would have run wmo if I had time to process bit dont run synthetic oil and keep the unleaded at a minimum. Personally id run heavy on the diesel and use dyed the black of the oil will mask the red thats my opinion
Devilish
Nv
This response is a little late but get a test pipe. Wmo quality can vary. Better to save the cat for inspections than plugging it up.
morerunner
