PLanB419
I was told by my cpa that the rule is you have to pay road tax when you buy fuel not to drive on the roads. Right wrong or Indifferent I'm sticking to that.
Good enough for me!
Hey there yousave1. I seen your post and im curious if you are still running the 6.7 on wmo.I set out to buy something to run wmo and ignorantly bought a 6.7. After 3K dollars it worked. I've been running heated - centrifudged wmo, atf, and such and the truck loves it. If I could do it again I'd buy a 5.9 and not deal with the deletes.
If you look at that guys profile, he hasn't logged in since 2012.Hey there yousave1. I seen your post and im curious if you are still running the 6.7 on wmo.
I have a 2008 6.7 deleted with stock injectors but has aftermarket turbo and manifold with fass 220gph lift pump. I also have slip tank in bed that holds 75 gallons. I just bought a pa biodiesel centrifuge and i just cleaned 55 gallons of hydraulic oil. Im able to get a endless Supply of hydraulic oil and wmo. Id really like to run this in my trk but dont want to screw up injectors or cp3. Tia
