advice on a budget tow rig
bobbybusch
San Jose CA
Haha all bad then..... luckily this won't be my daily driver, just a work truck. Thank you for all the info!
Clb
Another old truck
nannyfornia
Devils advocate....I just want the engine.
Love my idi, towcat is spot on!
Just a f.w.i.w. Kinda thing. Cummins
An idi will drag twins on a flatbed all day, add into the mix a fully rocked enclosed race trailer and your cost and maint. Go up. There are some verry impressive heavy haul #'s from members here!
1 ton Braking will be a key issue.
Carry on.
bobbybusch
San Jose CA
What a rearend gears do I want? I'm no against swapping them out when I get the truck I just tony know what ones are best
4.10 is your base. if you are pulling more than 10k/lbs gross trailer weight, 4.56-4.63 but you'll need to find someone to put them in.
junk
Paullina, IA
Once again - Towcat is dead on.
Also his mileage numbers are dead on with what I've experienced and heard from all those setups.
asmith
Atascadero, Ca
I have a 89 f250 460 c6 and i believe 4.10s and i can barley crack 10 mpg empty keeping it at 60mph. It is all stock. My 94 7.3 with a zf5, 35 in tires 4.10s lifted 4 inches, and a lumber rack dragging in the wind and i get 17 mpg with a couple hundred pounds of tools in it all the time. Neither is fast, but they pull anything.
Stubburnjd1
