96 k1500 suburban build. 5.7 to 6.5 TD
thumper_65590
United States
Hello everyone. I have a 96 suburban K1500 that I am performing a drive train swap in. The 4l60E had last 3 and 4, and the engine had developed a bad knock, so I figured it's time to do some upgrades to get exactly what I wanted. I had been searching for a 6.5 TD suburban for quite a while but had been unable to find one, so I decided to build my own. I have a fresh 6.5 TD installed in the engine bay now, as well as pulling the 4l60E and replacing it with a NV4500. Anyway, right now I am in the process of wiring up the new engine and computer. Now my dilemma/problems. My wiring harness/ecm for the 6.5 is out of a 94. I am in the process of combining the 2 harnesses into 1. I have the complete harness, including the interior harness from the c100 connector inside to the c100 connector in the engine bay. What I am looking for is a pin out of the c100 connector for the 96 5.7 harness, as I have been unable to find it. Any help would be greatly appreciated. Thank you.
Redblock
ohio
Pin​
Wire Color​
Circuit No.​
Function​
Component Connector Cavity​
DTC(s) Affected​
Possible Symptoms From a Faulty Circuit​
Connector Part Information​
  • 12129025
  • Blue C1 32 Pin Connector
1​
Not Used​
2​
Not Used​
3​
BRN/WHT​
633​
1X CMP Signal​
4​
PNK​
539​
Ignition Feed​
No Change​
5​
YEL/BLK DK BLU/WHT​
846 878​
Injector # 6 Control (1) Injector #8 Control (2)​
Rough Idle​
6​
Not Used​
7​
TAN​
1667​
H02S Low Bank 2 Sensor 1​
Fixed H02S Reading​
8​
PNK/BLK​
632​
CMP Low​
9​
Not Used​
10​
TAN/BLK​
422​
TCC Solenoid Control (7)​
No TCC​
11​
Not Used​
12​
DK GRN/ WHT​
428​
EVAP Purge Solenoid Control​
Purge Inop.​
13​
WHT​
687​
3-2 Control Solenoid (5)​
Incorrect Gear State​
14​
BRN​
436​
AIR Relay Control (3)​
15​
WHT​
696​
VSS Output Signal (Antilock)​
16​
Not Used​
17​
Not Used​
18​
GRY​
435​
EGR Control​
EGR Inop.​
19​
PPL/WHT​
1665​
H02S High Bank 1 Sensor 1​
20​
PPL​
1670​
H02S High Bank 1 Sensor 2​
21​
PPL​
1666​
H02S High Bank 2 Sensor 1​
22​
PPL/WHT​
1668​
H02S Bank 1 Sensor 3 (4) H02S High Bank 2 Sensor 2 (9)​
Poor Performance​
23​
Not Used​
24​
TAN​
1671​
H02S Low Bank 1 Sensor 2​
Fixed H02S Reading​
25​
TAN/WHT​
1653​
H02S Low Bank 2 Sensor 2 (9) H02S Low Bank 1 Sensor 1​
Fixed H02S Reading​
26​
TAN/WHT​
1669​
H02S Low Bank 1 Sensor 3 (4) H02S Low Bank 2 Sensor 2 (9)​
Fixed H02S Reading​
27​
Not Used​
28​
PPL​
574​
CKP Low​
No Start​
29​
LT.GRN/BLK​
822​
VSS Low​
30​
PPL/WHT​
821​
VSS Signal​
31​
YEL​
573​
3X CKP Signal (1) 4X CKP Signal (2)​
No Start​
32​
Not Used​
(1) 4.3L Only
(2) Except 4.3L
(3) 7.4L California Emissions Only
(4) 4.3L and 5.0L Only
(5) Automatic Transmissions Only
(6) Manual Transmissions Only
(7) 4L60E Automatic Transmissions Only
(8) 4L80E Automatic Transmissions Only
(9) 5.7L and 7.4L Only​
morerunner
