Mike Linger
I've got my engine short block ready to put back together and want to make sure my engine oil pump is within spec before the oil pan goes back on.
Is there a way to check that the existing stock oil pump meets the minimum required volume/pressure?
Are there measurements I can take that may allow me to repair it (add/change out shims, etc.) if necessary. I'm not enthusiastic about spending a couple of hundred dollars for a new pump in an engine that is not going to see high performance use and is just used for occasional hauling and a daily driver.
thanks! ................Mike.
