I've had this almost 5 years and I'm just downsizing to an IDI van so I don't need this anymore. It's been driven, not just sitting.
Minor left rear wreck in 2022 but not totalled. Fiberglass damage.
Happened right after C6 was rebuilt. Has deep aluminum pan with temperature gauge. Also a big Hayden 779 cooler and an in-line magnetic filter.
Lots of wood rot from past owner neglect causing massive roof leaks. All addressed. Still solid due to steel framing in the walls and cabover. Driven it down rough dirt and gravel roads (slowly) and it's still holding up.
Onan 4000W genset, gasoline, with it's own separate fuel tank permanently installed from the RV factory. Runs good. Newer fuel pump.
Overall very good mechanically, aside from small leaks. (engine, radiator, differential input)
$2500. Located in SW Arkansas. Clear AR title in hand, in my name.
