derjackistweg
Hi folks,
I recently replaced my already 12.000km alternator with a new one a had a split second short with the battery cable.
Alternator works now...
Fuel shut-off via key does not. So engine keeps on running.
7 or 8 years before I had the same problem after (!) it came from a shop. But after I did something it worked again. It is an ex.ambulance so I did a lot of de-wireing... probably a fuse that I replaced. I don´t know.
In addition: My key-on starter does not work either, since 7 years or so. Never found out why, I just put on a switch that goes to the starter directly. Works since years so I never wanted to deal with the probably broken starter relay that sits behind the headlight on my 93 E350.
BUT no shut-off is not so cool (I made a switch though ) So I want to repair this now.
Question: Which is the correct wire to the key switch? The Fuel shut-off has power when key-on and it must not have power when key-off. But it still does.
If this has something to do with a short, is there any relay/fuse that I need to check? (I already did all, inside and in the PDB, of course)
So key position and Fuel Shut-off must have a connection, which line is it. Especially from the inside starting, meaning the key
THX
THX
