01 no power hot
IDI87
California
Okay. I know nothing about cummins, zip zero zilch. Through a ford idi or a 6.0 at me and I'm fine. However my buddy needs help with his 01. Cold it runs fine but hot it has no power, blows blue smoke, and doesn't idle. Oh and no codes. Any ideas where to look?
Sent from my SM-G988U using Tapatalk
Philip1
Northeastern Nevada
I would recommend upgrading the lift pump at the same time as replacing the vp44. Doing so will.make the replacement pump last longer. The stock lift pump is poorly sized to the requirements of the engine and can cause the vp44 to overheat and eventually fail.
Ayla
Santa Clara, Ca.
Thats ok, I have an 01 & 02 with the VP44....... I converted to the P7100 injection pump.
Nanohawk
