Pino2234
Since we are all on the WMO topic, I've been trying to figure out a way to filter WMO.
I've been talking to a company that makes their own oil.
I asked him about using WMO for my fuel and actually after the use of oil in your engine there are tiny particles that you cannot filter with any filter, even 1 micro.
These particles actually can clog your injectors if not they will start making basically a film that will start to coat over your pistons reducing the distance between the head and the piston causing problems.
He suggested to pre-mix WMO and diesel (50/50 for ex) and oil will actually separate.
The good usable oil will be 5 inches from the bottom and up, for example.
All of the bad particles will settle to the bottom.
