Just dump some kerosene and/or RUG into old motor oil, run it through a centrifuge, and put it in the tank? This kinda pegs the "if it seems too good to be true" meter. What are the cons to this process, besides a stinky exhaust and possible additional wear on IP and injectors?
Bascially.
The most important thing in running any alternative fuel is the fuel being clean... so how ever you choose to do so whether it be wtih filters or a 'fuge, don't skimp out. Most blend W85 (85% clean used oil/ 15% RUG)
I just started doing this in the last month... I go the old fashion filter route... I fill a 55 gallon drum with used dirty oil and RUG and it settles for a few days minimum. I then gravity flow from this drum through a 10 micron house water filter... then a 5 micron house water filter... and then a 2 micron high performance cim-tek filter and into a new 55 gallon drum that I have mounted horizontally with a drain valve for filling fuel cans.
I add RUG before starting the filtration process because the RUG actually drops contaminants out of suspension allowing them to settle on the bottom of the drum. I also don't pump off the bottom of any of the drums... this allows room for settling.
Currently, I'm running a 50/50 blend... (50% W85 - 50% Pump Diesel) in my 4BTA Cummins powered '03 Tahoe. My only complaint so far is the idle haze but I've got a few things in the works to hopefully take care of that. Come warm months, I'll be running straight W85.
The main drawbacks are filter replacement, time/space to do it, initial cost, legallity (not paying road tax.. most don't worry about it but its worth mention)...
As far as filter replacement goes... most plug a few fuel filters right off the bat... the W85 is fairly good at cleaning the inside of the fuel tank so and junk that may be in the tank will shortly end up in your fuel filters. (Lucky for me that I had just finished my conversion and had just flushed and cleaned my fuel tank) I also replace fuel filters with every oil change or every other oil change... I do it no matter the fuel I'm running... being stranded by a $15 filter sucks..
Anyways... welcome to the forum. There is a TON of info and people willing to help.
-Chris
