rhkcommander
2 seconds to restart is fine when cold.
Yes verify the glow plugs are good. The wiring to them can be bad too, as well as corroded connections, bad fuse links, etc.
If it took several seconds the first try and 2 on an immediate restart, i would assume air intrusion. If you make a toggle switch with a large and a small ring terminal you can attach it to the starter relay big batter post and sense little post to crank while under the hood. You can then see if air comes out of the fuel filter Schrader or fuel right away. My old engine acted this way, always would have air hissing when cranking with key on until fuel built up. Wouldn't start till purged, then would start great till sitting 24+ hours
