rreegg
Im pretty sure the truck has had a slight pull to the left the entire time I’ve had it. With about a ton in the bed and on the freeway it is more noticeable - but not undriveable. When empty there is less of a pull but not as bad.
When braking the truck pulls to the left as well.
The tires are all equally inflated to about 65-70 psi. The steering (tie rods and drag link etc) are all new and have been aligned at a shop.
Far as I can tell none of the brakes are dragging and all read about 100* with the infrared thermometer after driving.
Any other tips as to what could be the cause here? Suspension or something else?
Truck is fine as is, obviously old, and I can live with things but would be nice to resolve this if possible.
The steering wheel has a little more play to the left than to the right - thought this was alignment related but it might be the steering system. Not very familiar with that yet though. From what I’ve read though most folks have some play in the wheel
