yosemiteyeti
i just recently got a 89 f250 with the 7.3idi and c6 4x4. the previous owner drove it to work said the transmission never slipped or made any noises on his way. he worked his shift and returned to his truck to find that it would not engage in any gear reverse drive 1st or second made no noise and would not go. he didnt want to deal with it so he sold it to me cheap. ive checked the fluid and its at the right level ive also checked the linkage, replaced the filter and cleaned the valve body and it still dose nothing, my uncle told me to pull the lines to the trans cooler to see if there was any presure and there is none in any of the gears. what im woundering is how do i tell if its the torque converter or the trans that went bad and if there is any other test i can do to trouble shoot and find the problem.
