I cleaned out the GP holes with a 7/16" Drill bit and used a Tap Handle
to screw down into each hole. 5 were tight with carbon. With the Injectors
out, blew air down it`s hole which blew out the GP hole to blow out any debris.
Picked up a thread chaser kit from O`Really`s, wanted to chase the GP holes,
But there wasn`t a correct bit with the correct thread.
M10x1.0 as per this thread.
Howdy, haven't posted in a good while. Got a 7.3 in the shop where previous excuse for a mechanic cross-threaded one of the glow plugs. Does anyone make a tap for chasing the threads in the glow plug hole? I'm sure I'm not the first poor soul to encounter this, but so far haven't found anything...
www.oilburners.net
Had a used Injector with me and asked the kid, ya got a thread chaser for one of these?
"What`s that"? "OH it`s a "Diesel Spark Plug".
Once the carbon was out the GP`s went right in. Be sure to throw on some Anti-Seiz.
I have the , Ford Rotunda OTC 6.9 7.3 Diesel Injector Nozzle Seat Cleaner T 83 T 9527 a 303 232 Reamed out each hole then threw in the copper washer and torqued the injectors.
I used a long thin Screw Driver, put the Copper washer on it, held it with my thumb,
Put the end down in the hole then let the washer slide down and the washer will be
where you want it.
Got the VP installed with the 4 gaskets, RTV the ends, install the drain plug, be sure to
install the hold down bracket and 4 bolts across the front before dropping the
Intake Manifold in place. I used a long tapered punch to line up the gaskets with the
VP and IM even though I used some stickem to hold them. Then the Bolts will go
right in.
As rusty as the bolts were taking them out. After wire wheeling them, put Anti-Seiz on the smooth part of the bolt and blue lock tite on the threads.
Be sure to install the engine lift hooks/eyes/rings.
I noticed the left rear 2 bolts didn`t go all the way down, maybe that rear hook goes
on that side? Oh well found another in my stash, wire wheeled it and painted it,
Throw it on tomorrow, and have 4 lift points.
Since I ripped out the crappie dirty FW insulation, spent good part of the afternoon
putting on some Dynamat. That was fun cutting the pieces, then laying across the
Engine and getting it on and rolled in. Was over 100deg today, so cutting it, getting
the paper off and getting sticky stuff on was fun.
If you use some Carb Cleaner and a rag, the lettering will come right off, then you
have just the shiny aluminum.
Picked up 6ft of Gates 3/16" hose for the return lines from O`Really`s. Dang pricy
stuff, over $3 a ft. But is what they Had.
I need the Olive for the fuel return tube from the IP to the rear connection. I cut the
tube short, going to run hose from IP back where the tube becomes straight. Then
use Rubber 3/8" hose off the pump.
There is a square block on the pump for a 3/4" wrench to move the pump, and the
Tube is in the way.
Stopped at the local Diesel Shop for an Olive, but was out. Guy did a search and
O`Really`s has them. Dorman 904-497 for $29, yikes. only one size for this tube,
and next size down and 4 that go to what ever.
Was out at the Hyd Shop to get an O Ring for the IP inlet fitting (did the push lock
rubber hose mod, Filter to IP) removed the fitting and figured the O Ring would leak changing pumps. $0.50
Hyd shop doesn`t carry the Olives, said Hydraulics and Automotive is different.
How does the cold fast idle Solenoid come off the bracket?
I want to clean it up before swapping to the new pump.
Don`t see a nut, is it press fit on?
