oldblue05
PIN IT TO WIN IT!!!
So I drove the truck 400 miles yesterday nonstop pulling an empty but HEAVY 20' bumper pull trailer with A/C on and 100+ temps with no relief, the gauges pretty much looked like this the entire time except when I rolled through a few small towns the temps would drop and when I pulled a few long grades and kept my foot in it the temps got up to the L of NORMAL.
Before I added all my new go-fast goodies the temps hardly ever got to the very first of the word NORMAL, is this typical for turbocharged diesels to run this much hotter?
I have an aluminum 3 core radiator, 2 puller 14" e-fans, 50/50 antifreeze and water, coolant filter with 8 dca's, using the trans cooler built into the rad to cool my powersteering fluid, air to water intercooler with 2 10" push fans, no holes in bumper for air flow(I plan to fix that on next bumper) stock thermostat, and a brand new water pump.
One other thing, it seemed that if I lowered the air speed from the A/C it would run cooler, would this be because the condenser is putting off less heat?
