tractorman86
i've got a deal for you guys here, $300 is all i want out of it, that is what i payed for it. The shaft dose have some play in it, if you really try you can get it to touch the housing so imho it needs a rebuild. it is short the oil feed and discharge and the intake snail, it has the cdr and the tube to hook it to your valve cover but you will have to drill a hole in the vc to use it. the up pipe is actually from a banks system and has almost no time on it, but it is missing the piece that actually bolts to the flange but it needs a little fabrication to work anyway.
