Brian VT
I ordered one of these filter heads from Ebay. I'm hoping to mount it where my stock one is (on the firewall). I guess it's a China copy of a Racor 490R10. If it fits well I'll see how long it lasts and if it's junk then at least I'll know that the Racor will work here and then I'll spend the $ for the Racor.
I've had it in my head that some day I'm gonna wish I had a primer. And I don't trust the stock filter that's still on my truck. So I'll be killing 2 birds with one stone if this works.
NEW Hand Priming Pump Diesel Fuel Filter Mounting Base M16*1.5 NPT 1-14" | eBay
Hand Priming Pump Diesel Fuel Filter Mounting Base 3/8" NPT 1-14" Spin On Mount. Hand Priming Pump With Air Vent/Bleed Port. 4x 3/8" NPT Threaded Fuel Ports. 2 Inlet Ports and 2 Outlet Ports Allow You To Connect Multiple Fuel Filters In Series or Parallel and You Can Have Fuel Enter or Exit From...
www.ebay.com
490R10 RACOR FUEL/WATER SEPARATOR ASSY WITH PRIMER PUMP
The Most Diverse, Extensive and Experienced worldwide Support for Heavy Duty Diesel Engines and the Equipment they power...
store.reliableindustries.com
