What kind of key/pin do I need for my t19 gearshift?
Diesel JD
Gainesville, FL
Yeah...anybody know? Nothing seems to fit quite right, and the auto parts guys are clueless. Thanks a thousand,
JD
subway
be nice to the admin :D
York PA
which pin? are you talking about the pins in the shifter cover?
RKOCH
Fellow Oil Burner
Yorktown, Virginia
You talking the pin that holds the shifter in the tower that wears out and gets real sloppy? If so Ford dealer.
Dave Barbieri
Overton, TX
Last Fall, I had the same problem. I'd been using a piece of mild steel dowel, cut to fit. Being mild steel, it wore pretty quickly, so the slop returned. A transmission guy in Dallas told me to take one of the bearing rollers that line the inside of the input shaft pocket (Where the nose of the output shaft fits in) and use it. Correct diameter, correct length. Also, it's hardened steel, so it doesn't wear. Did that seven months ago, and it's still going strong.
morerunner
