I'm adding a coolant filter and ran into something that kind of stumped me
In the coolant filter article it shows the inlet to the filter being fed off the line that comes out of the right side of the engine under the head. I thought that the supply to the heater core came off the 5/8 fitting on the water pump and the return went to the right side of the engine? Is the filter in the article installed opposite of what it should be? Or am I on crack and thinking backwards? Thanks for any insight
Andrew
Andrew
Turns out if I unbolt the coolant filter assembly (without removing the filter from the housing) I can move it out of the way and get to the fuel filter much easier. That said it makes it even more of a pita
Another thing that works is to slide the fuel filter in sideways and fill it once it is nearly in place--move it over--thread it in and viola!
