Part Numbers
Mike
Stroker
Cora
This is an alphabetical listing of the 7.3L Power Stroke parts list.
This list has been compiled through the work of many folks, I cannot garuntee the accuracy of all the numbers, so please before purchasing verify the part numbers. This should be used as a guideline for ordering/buying parts.
STARTING WITH THE "A's"
Accelerator Pedal (w/AP & IVS)
(Ford) F6TZ-9F836-AA (F-Series)
(Ford) F5UZ-9F836-B (Econoline)
APCM (Auxilliary Idle Controller)
(Ford) F5PZ-12B641-AA
(Ford) F5TF-12B641-AD with LCD display
APCM (Auxilliary Idle Controller) wiring harness
(Ford) XC3Z-14A411-AA
Air Dam
(Ford) F2TZ17626A
(Ford) F2TZ17626B
(Ford) F3TZ17626B (Fiberglass for Ford Lightning)
Air cleaner cover 94-97 F-series (Updated Cover)
(Ford) F6TZ-9661-AB
Air cleaner nuts 94-97 F-series (Updated Spring Loaded Steel Nuts)
(Ford) F7TZ-9B680-AA
Air cleaner assy 99 F-series
(Ford) F81Z-9600-BA
(Ford) XC3Z-9K635-AA (99.5 F-series--modification kit)
Air Filter (Stock)
(Amsoil) S1968
(Ford) F5TZ-9601-A
(K&N) E-1946
(Motorcraft) FA-1617 (F-Series)
(Motorcraft) FA-1618 (Econoline)
(Napa) 6417
Air Filter DoItYourself Type (Conical)
(ACDELCO) A1474C
(Air Refiner) ARM08-5011
(Baldwin) PA2818
(Big A) 94637
(Carquest) 88637
(Caterpillar) 3I0003
(Cummins) 2912986
(Cummins) 3912020
(Donaldson) B085011 or ECBO85011 H
(Fleetguard) AH1141
(FleetRite) AHR81141
(FRAM) CA6818
(GFF) AF359214
(General Motors Corp.) 25177209
(Hastings Premium Filter) AF2329
(Hercules) B085008
(Kralinator) LA1458
(K&N) RE-0860 (~12" long w/4" opening)
(Luber_Finer) LAF2533
(Napa) 6637
(Schupp) SL12903
(WIX) 46637 or 546637
(WOODGATE) WGA1138
Air Filter Gauge
(Ford) F7TZ-9N622-AA
Alternator
(Ford) F5UU-10300-CA 215Amp Ambulance alternator
Antifoaming Additive (counters RTV reaction with oil)
(Fleetrite) CH1824392
(Lubrizol) 888
Auto Hub Lock Grease
(Ford) E1TZ-19590-A
Mike
Stroker
Cora
"B's"
Bed Mount Insulators/Bushings 6 needed
(Ford) E9TZ-5C036-A
Belt (See Serpentine Belt)
Brake booster ZERO LOSS
(Ford) F5TZ-2005-CA
Brake Master Cylinder Sensor (at the end of MC)
(Ford) F3TZ-9F924-BB
Brake Pads
(Bendix) MDK655FM (fleet grade)
(Ford) XU2Z-2V001-ASA (Autolite with hardware)
Brake Shoes
(Bendix) AF583 (semi-metallic)
Bushings
(Energy Suspension) 4-7110 (radius arm; polyurethane 93-98 2WD F250-F350)
(Energy Suspension) 4-5106 (front sway arm; polyurethane)
(Energy Suspension) 4-5104 (rear sway arm; polyurethane)
(Energy Suspension) 4-4107 (Body mount bushings, 1980-1996)
(Energy Suspension) 4.3121 (2) (Axle Pivot Bushings, 90-96 2WD)
(Energy Suspension) 4.7115 (Track Arm Bushing 85-98 F350 4WD)
Bypass Filter
(Amsoil) BMK11 (base)
(Amsoil) SDF99 (spin-on filter)
(Amsoil) BE100 (replacement filter)
(Baldwin) OB1305 (base)
(Baldwin) B164 (large filter)
(Baldwin) B50 (smaller filter)
Mike
Stroker
Cora
"C's"
Camshaft Bearings, up to 8/1995, maybe later.
(International) 1812317-C92
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96
(Ford) F7TZ-12K073-A 97+
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
Camshaft Position Sensor O-Ring
(Ford) F81Z-12B615-BA
Camshaft Position Sensor (CPS) shim kit
(International) 1826583C91
Catalytic Converter Delete Pipe
(Ford) F4TZ-5A212V
(Ford) XC2Z-5A212-AA (SD type, cheap but must be shortened)
Clutch
(LuK) 07-154TFW (replacement 12" used w/SMFW; incl. SMFW)
(LuK) 07-127 (12-1/4" clutch replacement)
Clutch Master Cylinder
(Ford) F2TZ-7A543-D (96-97)
Clutch, Throwout Bearing
(BCA) FC65662
CMP Sensor
(Ford) F6TZ-12K073-A (C99) (94-96, parts suffix C96, 97, 98)
(Ford) F7TZ-12K073-A (C93) (97+, parts suffix C91, 92)
Coil Spring Shim, Height adjusting/leveling, F250 2wd
(Ford) 389117-S2 (service part, washer goes under coil spring)
Column parts; see steering and shift
Coolant Conditioner
(Fleetguard) DCA60L (DCA4)
(Ford) FW-15/FW-16
Coolant Eye
(John Deere) TY16423
Coolant Temp Sender
(F1SZ-10884-A (for gauge, mounts on water pump)
(F4TZ-10884-B (for overheat light, RH front of block)
Coolant Test Strips
(Fleetguard) CC6202 (50)
(Fleetguard) CC2602A (four strips)
(Fleetguard) CC2602B (one strip)
Crankcase Breather O-Rings
(Ford) F4TZ-6769-A (small; seals screw head; 1/pack)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover; 2/pack)
Mike
Stroker
Cora
"D's"
Dana 50 TTB Hub Lock Nut Tool
(OTC) 7158
Dana 50 TTB
(Ford) F6TZ-3N105-BB (spindle nut, washer, gasket, autohub bolt, retainer kit)
(Napa) BK1 (spindle bearing, inner & outer seal rebuild kit)
(Napa) 22311 (inner spindle)
(Napa) 711818 (outer spindle)
(Napa) 27452 (hub seals)
(Napa) B2110 (spindle bearings)
(Timken) 382A (wheel bearing; inner race)
(Timken) 387A (wheel bearing; inner bearing)
(Timken) SET38 (wheel bearing; outer bearing w/race)
Dana 50 TTB Wheel Bearings
(BCA) SET A-38
Dana 50 Grease Seal (NAT) 415960
(CR) 27467
Dash Pad
(Ford) F2TZ-1504282-BAD (mocha/tan)
Daytime Running Lights Module
(Ford) F43Z-15A272-A
Door Latch
(Ford) F2TZ-1521813-A
Door Inside Panel Push Fasteners
(Ford) N802900-S
Door Inside Panel
(Ford) F4TZ-1523943-BAD (mocha/tan)
Door panel light (clear lense)
(Ford)F2TZ-13734-B..Driver's side
Dipstick part numbers:
(Ford) F4TZ-6750-E (F-Series)
(Navistar) 1824405C1 If you have 1820068C1, it reads 2 qts low!!!
(Econoline) F5UZ-6750-A
Dipstick Mount Seal Repair Kit with instructions
(International) 1846146c91 (silicone, loctite gasket eliminator, adapter gasket, dipstick oring
Mike
Stroker
Cora
"E's"
Engine Belt (See Serpentine Belt)
Engine Cover Bracket/Mount
(Ford) F81Z-6A955-AA or YC3Z-6A955-AA (mount for 97-up shorty cover)
Engine Cover Nuts
(Ford) N800475S101
Engine Oil Temp Sensor (EOT)
(International) 1814320C1 (engine serial # 375548 and below)
(International) 1824451C1 (engine serial # 375549 and up)
Engine Oil Temp Sensor Connector
(International) 2501106C1
Exhaust BackPressure Regulator (EPR solenoid; up to 98.5)
(Ford) F5TZ-6C673-A
Exhaust BackPressure Regulator Valve
(Ford) F4TZ-9J460-A (94-96; mounts on bracket above oil reservoir)
(Ford) F7TZ-9J640-AA (97-up; may mount like earlier models, later in front of reservoir)
Exhaust BackPressure Regulator Valve Tube
(Ford) F4TZ-9D477-A
Exhaust backPressure Regulator EPR solenoid, up to 98.5
(Ford) F5TZ-6C673-A
Exhaust BackPressure sensor
(Ford) F4TZ-9J460-A (94-96; Mounts on bracket above oil reservoir)
(Ford) F7TZ-9J640-AA (97, mounts like earlier models; 98 and up, mounts in front of reservoir
Exhaust BackPressure Valve Actuator Seal Repair Kit
(Ford) 2C3Z-9P466-BA (94.5-97)
(Ford) 2C3Z-9P466-AA (98-02)
Exhaust Brake
(BD) 2033143
(Pacbrake) C15000
Exhaust Collector Donut (see turbo Exhaust Collector Donut)
Exhaust, Turbine Down Pipe
(BD) 1047310
Mike
Stroker
Cora
"F's"
Fan Belt; see serpentine belt
Flexplate Crankcase spacer (94-99)
(Ford) F81Z-6A366-AA
Flexplate Engine Spacer (94-99)
(Ford) F4TZ-6A369-A
Flexplate Reinforcement Plate (94-99)
(Ford) F4TZ-6A366-A
Flywheel, Dual Mass
(Ford)F-7TZ-6477-DA
Friction Modifier, Limited-Slip Differential
(Ford)F3TZ-19B546-MA
Front Crankshaft Oil Seal
(National) 3894VD
Fuel Conditioner Additives
(Stanadyne) 29409 (pint)
(Stanadyne) 31845 (1/2 gallon)
Fuel Lubricity Additives
(Ford) F8AZ-9C077-AA
(Stanadyne) 32398
Fuel Cap (Locking)
(Napa) 703-2614
Fuel Filter
(Baldwin) PF7678
(International) 1822631C91
(Motorcraft) FD4595
(Racor) IN F4595
Fuel Filter Drain Cable
(Ford) F7UZ9J312 (cable assembly)
(Ford) F7UZ9728 (mounting bracket)
Fuel Filter Housing
(Ford) F4TZ-9155-B (engine serial no. 201680-before)
(Ford) F6TZ-9155-A (engine serial no. 201681-up to 98.5)
Fuel Filter Housing Reseal Kit
(Ford) F5TZ-9157-A (94-95)
(Ford) F6TZ-9157-BA (96-97)
(International) 1823645C91 (94-95) (Part # inside Ford packaging, bad per IH)
Fuel Filter Housing wiring
(Ford) F7TZ-9S277-AA
(International) 1825754C91
Fuel Filter Lid
(International) 1825190C91
Fuel Filter Restricted sensor; on filter housing 94/95; on regulator block 96/97
(Ford) E8TZ-9S283-A
(International) 1809435c1
Fuel Filter Stand Pipe
(Ford) F5TZ-9236-A (94-97)
Fuel Filter Water in Fuel Control Switch, not the part in the bowl
(International) 1821712C1 (In harness behind HPOP reservoir pass. side)
Fuel Filter Wrench
(MATCO) KD3526
Fuel Heater Element; Includes thru housing connector
(Ford) F5TZ-9J294-A (94-97)
(Ford) F81Z-9J294-AA (98-02) Heavy duty, may interchange???
(International) 1825186C91
Fuel Heater External Connector
(Ford) F4TZ-9C065-A
Fuel Lift Pump Outlet Seals (seals banjo fitting of "wishbone" line)
(Ford) F4TZ-9A375-A
Fuel Line Damper (96/97 CA; mounts on lift pump banjo fitting)
(Ford)F6TZ-9N163-AA
Fuel Line Damper Gasket (copper washer; not included w/damper)
(Ford) F6TZ-9160-AA
Fuel Line Seals (seals lines at head inlet fittings)
(Ford) F4TZ-9C387-A (94-97)
Fuel Pressure Regulator (contains spring, valve spool & new brass plug)
(Ford) F5TZ-9K061-A (federal emissions; 94-98)
(Ford) F6TZ-9K061-AA (CA emissions; engine serial no. 201681-98)
Fuel Pressure Regulator Spring
(Navistar) 1823643-C1 (federal emissions; 94-98
(Navistar) 1825854-C1 (CA emissions; engine serial no. 201681-98
Fuel Pressure Regulator Screen Kit (Orifice Vent Kit) Includes screened plug, o-ring, check valve
(Ford) F5TZ-9A214-A
(International) 1823658C91 (doesn’t fit the PSD)
Fuel Pump
(International) 1824415-C92
(Ford) F6TZ-9350-A
(NAPA, Shucks, AutoZone etc) 61067
Fuel Pump, Banjo Fitting
(Navistar) 1821624-C92
Fuel Pump Banjo Gaskets
(Ford) F4TZ-9A375-A
(International) 182065C1
Fuel Rail Plug O-Rings (seals the small 1/4" square drive drain at ends of heads
(Navistar) 1815734-C1
Fuel Rail Plug
(International) 1822618C92
Mike
Stroker
Cora
"G's & H's"
Glow Plug
(AutoZone) ZD-10 or ZD-11 (Beru plugs)
(Ford) F4TZ-12A342-A
(International) 1820697C2
Glow Plug Deactivation Kit (opens at 115 degrees coolant temp)
(International) 1831142C91
Glow Plug Relay
(Allied Electronics) 576-1078 (Stancor Heavy Duty 586-902)
(AutoZone) MR99
(Ford) F7TZ-12B533-CA (94-96 with pigtail)
(Ford) F81Z-12B533-AC (96-early 2000 w/o pigtail)
(International) 1807230C2
(International) 1826634C94
(Napa) GPR-109
Glow Plug Relay shunt; Required for GP monitor circuit; 97 CA
(Ford) F7TZ-12B533-B
Headlight Assembly; 92-97
(Ford) F2TZ-13008-A (RH)
(Ford) F2TZ-13008-B (LH)
High Pressure Line (hydraulic clutch)
(Ford) F5TZ-7A512-A
High Pressure oil rail o-rings For rail plugs, elbows and ICP
(Ford)F4TZ-9N693-A
High Pressure Oil Pump (Includes F81Z-AA IPR valve; uses F4TZ-A gasket)
(Ford) F4TZ-9A543-BRM (engine serial no. up to 201680)
(Ford) F6TZ-9A543-ARM (engine serial no. 201681 through 99)
(Ford) F81Z-9A543-CA (99.5)
(Ford) F81Z-9A543-BRM (98.5/99)
(Ford) F81Z-9A543-CRM (99.5)
High Pressure Oil Pump Gasket
(Ford) F4TZ-9417-A (engine serial no. 201680 & before)
(Ford) F6TZ-9417-A (engine serial no. 201681 & up
High Pressure Oil rail end plugs Large plugs at each end of heads; incl. o-rings
(International) 1827535-C91
High Pressure Oil Reservoir
(Ford) F4TZ-6658-A (engine serial no. 201680 & before)
(Ford) F6TZ-6658-AA (engine serial no. 201681 up to 98.5)
High Pressure Reservoir Gasket
(Ford) F4TZ-6619-A -Engine number 201680 & below; partial gasket RTV required
(Ford) F6TZ-6619-AA -Engine number 201680 up to 98.5; full gasket, no RTV
High Pressure Oil Supply Hoses
97 and before
LH: F6TZ-9A332-A
RH: F6TZ-9J323-A
98 and up
LH: F81Z-9A332-AA
RH: F81Z-9J323-AA
High Pressure Oil Supply Fittings
(Ford) F4TZ-9N332-A (elbows on cylinder head oil rails)
(Ford) F4TZ-9C402-A (HP oil pump fitting and o-ring)
High Pressure Quick-connect fitting on cylinder head oil rails; 98 up
(Ford)F81Z-9N332-AA
Horn Pad; see Steering Wheel
Hub Nut Removal Tool
(OTC) 7158 (94)
(OTC) 7157 (later)
Mike
Stroker
Cora
"I through N"
ICP Sensor
(Ford) F4TZ-9F838-A (94/95)
(Ford) F6TZ-9F838-A (96-up; marked Julian date 6318 or higher)
(International) (94/95) 1830669C92 $128
(International) (96-up) 1807329C92
Idler Pulley; see Serpentine belt Idler
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
IPR Valve
(Ford) F4TZ-9C968-C (engine serial no. 187099 & before or pump no. 255C92)
(International) 1824982C91 (engine serial no. 187099 & before or pump no. 255C92)
(International) 1833798C91 (All Years ???) latest part number
(Ford) F81Z-9C968-AA (engine serial no. 187100 & up or pump no. 247C91)
Injectors
(Ford) F81Z-9E527-DRM (federal emissions & SuperDuty)
(Ford) F81Z-9E527-ARM (California emissions)
(Ford) F81Z-9E527-BRM (99.5 only)
Injector O-ring kits (replaces all previous kits, 8 needed)
(Ford) XC3Z-9229-AA
(International) 1833564C91
Injector Removal Tool
(OTC tools) 6067
Injector Driver Module (IDM)
(Ford) F7TZ-12B599-AC (F-Series)
(Ford) F6TZ-12B599-AA (Econoline)
(Ford) F6UZ-13C795-AA & -BA (seals for Econoline)
IDM seals for E-van
Intake Hose Kit (update replaces orange hose)
(Ford) F7TZ-9C681-AA
Intake Plenum
(Ford) F81Z-9E434-DA (96-03 newer type with screen, 10 bolt and 3")
Lift Pump; see fuel pump
MAP Sensor
(Ford) F4TZ-9F479-A (94-98; digital)
Neutral Safety Switch (hydraulic clutch)
(Ford) FF57Z11A152A (96-97)
Mike
Stroker
Cora
"O's & P's"
Oil, Anti-Foaming Additive
(International) CH1824392
Oil Cooler Housing 94-97; Updated snap ring retained check valve
(Ford)F81Z-6881-BA
Oil Cooler Housing Gasket (front)
(Ford) F7TZ-6A636-A
(International) 1831666C1
Oil Cooler Housing Gasket (rear; oil filter end)
(Ford) F4TZ-6A636-AA (97-up)
(Ford) F4TZ-6A636-B (96-before)
(International) 1831665C1
Oil Cooler O-Rings (one each to seal cooler at each header)
(Ford) E3TZ-6C610-A
(Ford) E4TZ-6K649-E
(International) 1807563-C1, Inner 1804414-C1 Outer
Oil Filter
(Fleetguard) FL3630 - 11.51
(International) 181456261 - 11.51
(Motorcraft) FL1995
Oil Filter Housing 94-97 (updated snap ring retained check valve)
(Ford) F81Z-6881-BA
Oil Fill Extension (6" Super Duty style, uses same cap)
(Ford) 4C4Z-6783-AA
Oil Pan Drain Copper Gasket
(Ford) F4TZ-6734-B
Oil Pressure Sender Switch
(Ford) F4TZ-9278-A (engine serial no. 201680 & before)
(Ford) F6TZ-9278-AA (engine serial no. 201681 up to 98.5)
Oil Rail End Plugs (large plugs at each end of heads; incl. O-rings)
(Navistar) 1827535-C91
Parking Brake Cables, Crew Cab LWB
(Ford) F6TZ-2A635-C (Driver’s Side)
(Ford) F6TZ-2A635-CC (Passenger Side)
(Ford) F2TZ-2A793-A (Intermediate Cable)
Piston, Pin & Rings
(Ford) F4TZ-6102-A (engine serial no. 201680 & before)
(Ford) F5TZ-6102-A (engine serial no. 201681 up to 98.5)
Mike
Stroker
Cora
"R's & S's"
Radiator Hose
(Ford) F5TZ-8260-E (upper)
(Ford) F5TZ-8286-G (lower)
Radiator Core Support
(Ford) F4TZ-16138-A
Receiver Hitch, front
(Drawtite) 65015
Relay Shunt (required for glow plug monitor circuit; 97 CA emissions)
(Ford) F81Z-12B533-BA
Restricted Fuel Filter Sensor; see fuel filter restricted sensor
Rocker Arm
(International) 1814259-C91
RTV Silicone Sealer
(Ford) F5TZ-19G204-AB
(Wacker) T-442
Seat Belt Extension
(Ford) E3FZ-61611C22-B Extension I got from Ford Dealer, about 10"
(Ford) FO3Z-5461248-A Belt adjustment clip for child seat
Seat Foam, Lower Captains Chair
(Ford) F2TZ-18632A22-B
Serpentine Belt
(Ford) F6TZ-8620-GA (1995-up 8 rib)
(Ford) F5TZ-8620-A (1994.5 7 rib)
(Napa) 25-081189 (1995-up 8 rib)
(Unknown) JK7-1201 (1994.5 7 rib)
(Goodyear Gatorback) 4071195 (1994.5 7 rib)
Serpentine Belt Tensioner
(AutoZone) 199236
Serpentine Belt Idler Pulley (Lower Grooved)
(Ford) F6TZ-8678-HB
Serpentine Belt Dual Tensioner Upgrade MOD
(Ford) F8UZ-6B209-CA Dual Tensioner (E series)
(Ford) F8TZ-8620-FB Belt (F-Series)
(Ford) F8UZ-8620-BA Belt (E-Series)
(Ford) F8UZ-8B656-AB Decal to replace old
SD Pickup tensioner F8TZ-6B209-BA (easier to change belts per MASAMI)
Belt, Motorcraft JK8-1227, 122-7/8" long
Ford 1CZ-8620-LA
Shift Lever Rebuild Parts, Automatic
(Ford) 1F1Z-7212-AA Transmission Tube $17.09
(Ford) F3TZ-7L278-A Bushings (need 2) $1.76ea
(Ford) F7DZ-7R264-AA Plunger $10.60
Slave Cylinder
(Ford) E3TZ-7A564-A (96-97)
Sonnax Valve
(AX4N) 96948-01K - .427" dia
(Early E4OD) 36948-05K - .375" dia
(Late E4OD) 36948-03K - .331" dia
Starter
(Advance Auto Parts) 17250 (World Wide Automotive Remanfactured)
(AutoZone) 17250 (Duralast-import)
(Ford) 11002
Starter Solenoid (mounted on starter motor - can be serviced separately)
(Ford) F4TZ-11390-A (F4TZ-9N332-A ???)
Steering Column Shifter parts; see shifter
Steering Wheel
(Ford) F6TZ-3600-AA (MAY BE A BAD NUMBER)
Steering Wheel pad, with Horn and Cruise 92-97
(Ford) F2TZ-13A805-F
Steering Column Upper Bearing Kit
(Ford) F6AZ-3605-AA (contains steel tolerance ring, steel sleeve, bearing pre-load spring, upper bearing snap ring, steering wheel attaching bolt, small upper bearing, large upper bearing, & instruction sheet)
(Ford) FODZ-3L539-F (as above but no bearings)
Mike
Stroker
Cora
"T's"
Temp sending unit; see "engine oil" or "coolant"
Thermostat
(Ford) F4TZ-8575-A (engine serial no. 201680 & before)
(Ford) F6TZ-8575-AAA (engine serial no. 201681 up to 98.5)
(Intl) 1812314C94 (203 degree?)
Thermostat Gasket (o-ring)
(Ford) F4TZ-8255-A
(Intl) 1821880C2
Thermostat Housing
(Ford) F4TZ-8592-AA
Throttle Assembly (Includes Pedal, TPS, & IVS) 94-97
(Ford) F5TZ-9F836-A (f-Series) 94-95
(Ford) F6TZ-9F836-AA (F-Series) 96-97
TPS (Throttle Position Sensor) 94-97
See "Throttle Assembly" (May not be Available Individually)
(Ford) F2TZ-9B989-C (recently available, haven't confirmed it works yet)
Tie Rod
(Moog) ES 3363T (95-96 F250; right outer)
(Moog) ES 3362L (95-96 F250; left outer)
(Moog) DS 1419 (95-96 F250; connecting rod)
(Moog) DS 1420 (95-96 F250; left inner)
Timing Cover; Front
(Ford) F4TZ-6016-A (engine serial number 201680 & before)
(Ford) F6TZ-6019-AA (engine serial number 201681 thru 96)
(Ford) F7TZ-6019-AA (97-up)
Torque Converter
(Ford) XL3Z-7902-DAR-M (2002 4R100 type, can replace E4OD converter)
Transmission cooler line check valve
(Ford) FOTZ-7D174-A, inline upgrade for models w/o
(Ford) FOTZ-7D174-B, with 5/16 line
(Ford) FOTZ-7D174-C, with 3/8 line
Transmission Cooler
(B&M) 70264 (24K; stacked plate)
Transmission Dipstick; 4R100 Style, 12" longer but needs tweaking to fit
(Ford) Dipstick-F81Z-7A020-BA
(Ford) Tube-XC3Z-7A228-AA
Transmission Filter
(Ford) F6TZ-7A098-BB (with seal)
(Napa) 1-7825 (Magnetronic in-line)
(Autozone) TF-350 (2wd E4OD & 4R100)
(Autozone) TF-325 (4wd E4OD & 4R100)
Transmission Gasket
(Ford) F6TZ-7A191-A (reusable)
(Ford) E9TZ-7A191-A
Transmission Pan with Drain (4R100 pan, fits E4OD & uses same filter; must use reusable gasket above)
(Ford) F81Z-7A194-BA (4wd, deep)
(Ford) F81Z-7A194-AA (2wd, shallow)
Turbo Brake
(Western Diesel) WD99TB
Turbo Charger Assembly (remanufactured)
(Ford) F6TZ-6K682-ARM (up to 98.5; turbine & compressor)
(Ford) F4TZ-6K682-BRM (up to 98.5; complete-incl pedestal & EPR)
(Ford) F8UZ-6K682-AARM (98.5/99 Econoline w/o EBP)
(Ford) F81Z-6K682-AARM (99 F-series w/o EBP)
(Ford) F81Z-6K682-AA (99 F-series w/EBP)
(Ford) XC2Z-6K682-AARM (99.5 Econoline w/o EBP)
(Ford) F81Z-6K682-CARM (99.5 F-series w/o EBP)
(Ford) F81Z-6K682-BARM (99.5 F-series w/EBP)
Turbo Compressor Outlet to Y-Pipe O-Ring
(Ford) F4TZ-9E436-A (94-99)
Turbo, Compressor Wheel
(Schwitzer?) 170293 C/W
Turbo Exhaust Collector (up-pipe) Donut (at top of each manifold-to-turbo pipe)
(Ford) F4TZ-6K854-C
Turbo Exhaust Inlet Gasket (between turbo inlet & collector)
(Ford) F4TZ-6N640-B
Turbo Pedestal
(Ford) F4TZ-6N639-A (up to 98.5)
(Ford) F81Z6N639-BA (99 F-series w/o EBP)
(Ford) F81Z-6N639-AA (99 F-series w/EBP)
(Ford) F81Z-6N639-DARM (99.5 F-series w/o EBP)
(Ford) F81Z-6N-639-CARM (99.5 F-series w/EBP)
Turbo Pedestal O-Rings (between pedestal & block; pedestal & turbo)
(Ford) F4TZ-6N653-A & -B
Turbo Seals and Bearings, Kit
(World Products) 7-A-2058
Turbo Y-Pipe Quad ring
(International) 1818372C1
Mike
Stroker
Cora
"U's through Y"
U-Joint Kit
(Ford) EOTZ-3249-A
(Napa) 232 (heavy duty; Dana 50 4600 front GAWR)
(Napa) 231 (regular grade; Dana 50 4600 front GAWR)
Under Valve Cover Harness
See Valve cover harness
Upper Oil Rail (see high pressure oil)
Vacuum Pump
(AutoZone) 64-1008 (94-95)
(Autozone) 64-1024 (96-97)
(Ford) F4TZ-2A451-A (94-95)
(Ford) F6TZ-2A451-AA (96-97)
(Kragen/PartsAmerica) 641008 (94-95)
(Kragen/PartsAmerica) 641024 (96-97)
(Napa) 641 008 (94-95)
(Napa) NVP641024 (96-97)
Vacuum Pump, Electric, As used on ****** diesels and some GM cars
(Ford) E4FZ-2A451-A
(GM) 22034995
(Autozone) 64-1501 or VP3 or 64-1500 (GM)
(Kragen) 641501
Vacuum Pump, Electric, Super Duty accessory type, may be too small to run Booster.
(Ford) F81Z-2A451-BA
Vacuum Pump Pulley
(Ford) F5TZ-2L487-A (94-95) ???
(Ford) F5TE-2L487-AA (96-97) ???
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
Up-Pipe Donut (see turbo Exhaust Collector Donut)
Vent Register
(Ford) F3TZ-19893-H
Water in Fuel Sensor (See Fuel Filter Water in Fuel Sensor)
Water Pump
(Ford) F81Z-8501-BRM (engine serial no. 201680 & before)
(Ford) F81Z-8501-CRM (engine serial no. 201681 up to 98.5)
(Napa) 58-511
(Autozone) FWP-9045 (94-95 with pipe thread heater hose fitting)
Water Pump Inlet Pipe Gasket (o-ring)
(Ford) F81Z-8255-AA
Wheel Center Caps
(JC Whitney) 47BU0361A (2WD; aluminum bullet-hole rally style)
(JC Whitney) 47BU0362R (4WD; aluminum bullet-hole
Wing Window Handle Kit
(Ford) E9TZ-1522916A (RH)
(Ford) E9TZ-1522917A (LH)
Y-pipe
See turbo Y-Pipe
truckonfire
