Goofyexponent
Mentally Unstable..
I'll make this quick and painless....truck in my sig, accurate milage in my sig too. E4od overdrive light blinking and HARD shifts!! I mean HARD shifts. BigRigTech has a friend with a scanner, so I am going to try and fix this before it blows a gasket..
..On the off chance that this transmission needs serious $$, I will be putting a 5 or 6 speed into the truck. What year trucks can I pull a transmission from and have it fit my 1993 F250 IDI NON turbo.
I realize that I wil need a 4wd transmission, unless I pull one from an Fsuperduty with the transmission mounted E-brake.
Will a 6 speed from a new ford truck fit? Will I have to cut and weld the crap out of my floor and crossmembers?
And can I use both the ZF 42/47's or does it have to be one or the other specifically? I was under the understanding that both transmissions were the same casings.
