Look at what I found on CL
EMD_DRIVER
Say what?!?!
Beaufort, SC
I saw an ad, for a 7.3 non-turbo motor. The guy said there had been a problem with the #8 cylinder losing compression, but that was about it. Since the price was right, I figured I could pick it up and use it for some extra parts. It came with the IP, injector lines, new GP's and what I guess to be the flex plate.
If nothing else, I'll have a spare crank, heads, oil cooler, oil pan, intake, injector lines and an IP that can be used as a core. He even threw in a generator for the same price as the motor.... FREE! :thumbsup:
RLDSL
Diesel fuel abuser
Arkansas
Nice collection of goodies. How much did you have to fork over for that little collection?
VanBoy
WA
Nice. But how many Ben Franklin's did you have to fork over....
discbrks
Columbus, GA
Lucky dog... you wouldn't happen to have a spare set of valve covers I could bolt on to this motor after I get the turbo off, do ya?
EMD_DRIVER
Say what?!?!
Beaufort, SC
The guy that gave me this motor, said that there was low compression in the #8 cylinder. The diesel mechanic that looked at it, told him it was a faulty "Oil injector" I've never heard of that one...
If this turns out to be a good motor, I have no idea what I'll do with it. I mainly got it for parts.
Any thoughts?
4x4TruckinGirl
"Cowgirl"
Dixon, MO
if it were a good motor, or thought to be good.... you could tear it apart still and double check that is in pristine condition, then drop it in the 93 and rebuild that motor...... or ditch the 6.9 in your 87 and stick the good 7.3 in it........ yup yup yup
EMD_DRIVER
Say what?!?!
Beaufort, SC
I will be tearing into it, as time permits... I could always use the rockers in the 6.9.. I'm assuming that the oil cooler would work for either motor. The guy never said if there were air bubbles in the coolant, so I don't know if it could have cavitated.
The valve covers are already spoken for... They will be put on the truck that my turbo is coming off of.. :thumbsup:
