EMD_DRIVER
Say what?!?!
Haven't been able to drive my truck in weeks and it's bugging me big time! I started the ball joint job today, but didn't get very far. I ran out of tools
I thought for sure, that I had a socket that would fit the nuts on the ball joint studs, but my old-timer's must have gotten the best of me
I started this thread, so that others may be able to learn. I'm taking pictures during the process, so if there are any picture requests.... Ask away!
Here's what it looks like, with the Allen screws and hub cover removed. I wiped-off some of the grease, to give a better view.
From right to left, here's the order that things came out. Far right in the pic, is the hub cover. Far-left in the pic, is the first spindle nut.
Far-right is the hub and far-left is the outer wheel bearing.
This is the spindle, with the axle shaft sticking out the end.
This is the axle shaft, with the spindle removed. I used a chisel and a BFH on the spindle (After removing the 5 nuts!) The spindle came off in less than 5 minutes.
This is the back of the rotor assembly. It still has the inner wheel bearing in it, as well as the seal. I will be cleaning and re-packing the bearings and replacing the seal.
I'll be updating this thread, as the project continues. I'll document both sides.
