MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,702
- Reaction score
- 142
According to what I can make out from this at location C/D 14 and 15 :
Picture courtesy of AGNEM, thanks.
http://image18.webshots.com/18/1/79/32/202817932OgmYDQ_fs.jpg
: The fan-blower speed is governed by the GROUND being switched through a series of resistors, RIGHT ??
Lets say I splice into the BLK wire near the blower and also the ORG wire with good heavy wire, routing both leads through TWO simultaneously switched RELAYS, such that one relay gave full power to the ORG wire, and the other relay made a direct GROUND for the BLK wire, then would I be able to switch my blower to un-hampered FULL power by merely flipping a switch; and, when the switch was OFF, still have normal anemic factory-original control of fan speed, RIGHT ???
Thanks.
Thanks.
