Reefdiver72
Sludge Slinger
This morning I went and started my truck after filling both tanks up with 90%waste oil and 10%mineral oil I have 70gallons laying around is the mineral oil story. Well it started great not plugged in at 44degrees I let it run for about 10 minutes to get things warmed up and then took off well I made it to the neighbors driveway and it ran out of fuel so I restarted it fired up slowly backed down to my driveway it died again out of fuel so I jumped under it to look for a place to put a fuel pump went and got one and put it in line under the drivers door on the frame I wired it to the key and a switch just in case. wel I fired it back up and took off down the road ran great turned off teh pump and it died almost instantly. I think the wmo was just a little to thick for the standard pumps to get up to the pump.
The only other problem I have had is that alot of garages also dump waste gas bad gas into therte waste oil so be very careful with this I smelled it thankgod before I put it into my filter system I have been adding about 3 gallons of the 55 drum at a time with no effects I put a vent on the drum to vent the gas out of it.
I think we need to watch the vicosity or add an additional pump if you dont want to get stranded somewhere on the road I also carry 5 gallons of diesel to pour in to thin it down if need be,
On the last batch I made I got 33 miles to the gallon I had about 2 hours in making the batch of fuel and maybe 5.00 in materials. beats 210.00 at the pumps
