Electronic Cruise Control Diagnosis
Status
Not open for further replies.
Many thanks to member DOC, for transcribing the following service manual text. This text applies to electronic (not vacuum operated) cruise control systems in F and E series vehicles.
Speed Control Servo Assembly Connector
Speed Control Inoperative
A1 – Verify there is poser to the servo
- Disconnect the servo harness connector
- With the ignition switch in the on position measure the voltage between pin 7 (vehicle power) and pin 10 (ground)
- The voltage should be at least 12v
If yes, go to A2; If not, got to B1
A2 – Check for stuck stop light circuit
- With the brakes applied, check the voltage between pin 4 (brake input) and pin 10
- Is there 12v?
If yes, go to A3; If not, Stoplight switch is stuck on. Replace stoplight switch
A3 – Check brake/clutch circuit
- With the ignition switch off, measure resistance between pin 4 and pin 10
- Is the resistance at least 20 ohms?
If yes, go to A4; If not, Brake light bulb is blown or brake circuit is open. Service circuit including clutch pedal position switch
A4 – Check deactivator circuit
- With ignition off and no brakes applied, measure voltage between pin 9 (deactivator) and pin 10
- is there 12v?
If so, go to A5
A5 – Check for stuck on switch
- With no speed control switchs depressed, check voltage between pin 5 (command switch) and pin 10
- Is the 12v?
If so, go to A6; If not, replace switch
A6 – Check for switch operation
- With ignition off and steering wheel ON switch depressed, measure voltage between pin 5 and pin 10
- Is the 12v?
If so, go to A7; If not, go to D1
A7 – Check for stuck command switches
- With ignition off and no switches depressed, check resistance between pin 5 and pin 10
- Is the resistance greater than 3K ohms?
If so, go to A8; If not, one of the switches is bad, replace the switch
A8 – Check set/Accel switch
- With ignition off, depress Set/Accel switch and measure resistance between pin 5 and pin 6 ( command return)
- Is the resistance approx 680 ohms?
If so, go to A9; If not, switch no functioning, replace switch
A9 – Verify speed signal
- Raise rear wheels and operate at speed of 30 mph. Measure voltage between pin 3 (Speed Signal) and pin 10.
- is reading 4 – 5 volts?
If so, go to A10; If not service programmable Speedo/Odometer
A10 – Check for broken or bound actuator cable
- Remove speed control actuator from speed control servo. Check for broken speed control actuator by pulling on speed control actuator and noting throttle movement
- Is speed control actuator ok?
If so, replace stoplight switch; if not, or if binding or broken, service speed control servo
No Power to Servo
B1 – Check ignition circuit
- Make sure step A1 has been done.
- With ignition in the Off position, measure the resistance between pin 10 and a ground on the chassis.
- Is resistance less than 1 ohm?
If so, module power is okay, recheck A1; If not, there is a ground circuit open. service as required
No Power on Deactivation Switch Input
C1 – Check deactivator switch
- Make sure step A4 has been done
- Remove body harness connector from deactivator switch. Measure resistance between the two pins of the deactivator with no brakes applied
- Is the resistance less than 1 ohm?
If so, deactivator switch is okay, go to C2; If not, replace deactivator switch
C2 – Verify there is power to deactivator harness connector
- Measure voltage between pin 1 of the deactivator switch harness connector and chassis ground
- Is there 12v?
If so, go to C3; If not, Service blown fuse of deactivator switch
C3 – Check for open circuit between deactivator switch and servo
- Measure resistance between pin 2 on the deactivator switch and pin 9 on the speed control servo connector
If so, repeat step A4; If not, open wire harness, service as required
Steering Wheel ON Switch Inoperative
D1 – Check for open circuit in switch ground
- Make sure step A6 has been done
- With horn depressed measure voltage between pin 6 and chassis ground.
- Is there 12v?
If so, replace On switch; If not, Open circuit or blown fuse in horn relay feed or open circuit in switch ground. Service as required, repeat step A6
__________________
Doc
Status
truckonfire
